[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/verbose.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Sep 25 05:53:02 EDT 2006
Hello markus,
ANALYSIS
lib/gis/verbose.c functions
G_verbose (Begins at: 36 Ends at: 52)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_verbose_max (Begins at: 59 Ends at: 62)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
G_verbose_min (Begins at: 69 Ends at: 72)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-25 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
