[GRASS-QA] GRASS QA: jachym |
./grass6/general/manage/lib/do_remove.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Sep 27 12:23:19 EDT 2006
Hello jachym,
ANALYSIS
general/manage/lib/do_remove.c functions
do_remove (Begins at: 11 Ends at: 63)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 53 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
