[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.le/r.le.setup/sample.c |no clones | 10 monsters | 2 warnings
Thu Sep 28 05:28:15 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.setup/sample.c functions
sample (Begins at: 36 Ends at: 100)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      16 |       |      OK |
LOC:          |      65 |       |      OK |
at least 1 values are close to an outlier please consider revising code
man_unit (Begins at: 106 Ends at: 636)
Complexity:   |      57 |   *** | MONSTER |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |     157 |   *** | MONSTER |
LOC:          |     531 |   *** | MONSTER |
4 metric are OUT OF RANGE!
draw_grid (Begins at: 641 Ends at: 702)
Complexity:   |       3 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |       8 |       |      OK |
LOC:          |      62 |       |      OK |
1 metric are OUT OF RANGE!
calc_unit_loc (Begins at: 707 Ends at: 942)
Complexity:   |      28 |    ** | Warning |
ParamNBR:     |      22 |   *** | MONSTER |
CalledNBR:    |      44 |     * |         |
LOC:          |     236 |    ** | Warning |
get_rd (Begins at: 947 Ends at: 959)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
f (Begins at: 964 Ends at: 969)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
overlap (Begins at: 974 Ends at: 980)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
calc_num (Begins at: 987 Ends at: 1022)
Complexity:   |       4 |       |      OK |
ParamNBR:     |      11 |   *** | MONSTER |
CalledNBR:    |       4 |       |      OK |
LOC:          |      36 |       |      OK |
graph_unit (Begins at: 1024 Ends at: 1419)
Complexity:   |      35 |    ** | Warning |
CalledNBR:    |     117 |   *** | MONSTER |
LOC:          |     396 |   *** | MONSTER |
3 metric are OUT OF RANGE!
draw_box (Begins at: 1424 Ends at: 1453)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      11 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
draw_circle (Begins at: 1458 Ends at: 1498)
CalledNBR:    |       7 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
numtrap (Begins at: 1503 Ends at: 1571)
Complexity:   |      10 |       |      OK |
LOC:          |      69 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-28 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
