[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.contour/main.c |no clones | 0 monsters | 1 warnings
Thu Sep 28 12:27:17 EDT 2006
Hello jachym,
ANALYSIS
raster/r.contour/main.c functions
main (Begins at: 53 Ends at: 199)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      70 |    ** | Warning |
LOC:          |     147 |     * |         |
at least 1 values are close to an outlier please consider revising code
get_z_array (Begins at: 202 Ends at: 218)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
getlevels (Begins at: 222 Ends at: 320)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      26 |       |      OK |
LOC:          |      99 |       |      OK |
metrics are OK
displaceMatrix (Begins at: 328 Ends at: 352)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-28 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
