[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.cross/renumber.c |no clones | 0 monsters | 0 warnings
Thu Sep 28 12:27:17 EDT 2006
Hello jachym,
ANALYSIS
raster/r.cross/renumber.c functions
renumber (Begins at: 24 Ends at: 50)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-28 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
