[GRASS-QA] GRASS QA: maciej | ./grass6/vector/v.clean/main.c |no clones | 3 monsters | 0 warnings
Fri Sep 29 14:47:23 EDT 2006
Hello maciej,
ANALYSIS
vector/v.clean/main.c functions
main (Begins at: 32 Ends at: 360)
Complexity:   |      55 |   *** | MONSTER |
CalledNBR:    |     175 |   *** | MONSTER |
LOC:          |     329 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-29 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
