[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/raster.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 2 23:10:31 EDT 2007
Hello glynn,
ANALYSIS
lib/display/raster.c functions
D_draw_raster (Begins at: 38 Ends at: 45)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 8 | | OK |
metrics are OK
D_draw_d_raster (Begins at: 47 Ends at: 53)
ParamNBR: | 3 | | OK |
LOC: | 7 | | OK |
metrics are OK
D_draw_f_raster (Begins at: 55 Ends at: 61)
LOC: | 7 | | OK |
metrics are OK
D_draw_c_raster (Begins at: 63 Ends at: 86)
LOC: | 24 | | OK |
metrics are OK
D_draw_cell (Begins at: 88 Ends at: 94)
LOC: | 7 | | OK |
metrics are OK
draw_cell (Begins at: 96 Ends at: 146)
Complexity: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 51 | | OK |
metrics are OK
D_cell_draw_setup (Begins at: 148 Ends at: 164)
CalledNBR: | 7 | | OK |
LOC: | 17 | | OK |
metrics are OK
D_draw_raster_RGB (Begins at: 166 Ends at: 213)
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 17 | | OK |
LOC: | 48 | | OK |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
