[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/loc_proto.c |5
	clones ( main.c main.c main.c main.c com_proto.c loc_proto.c
	)| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Apr  4 03:06:08 EDT 2007
Hello glynn,
ANALYSIS
lib/raster/loc_proto.c functions
LOC_screen_left (Begins at: 25 Ends at: 41)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
LOC_screen_rite (Begins at: 43 Ends at: 59)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_screen_bot (Begins at: 61 Ends at: 78)
LOC:          |      18 |       |      OK |
metrics are OK
LOC_screen_top (Begins at: 80 Ends at: 87)
LOC:          |       8 |       |      OK |
metrics are OK
LOC_get_num_colors (Begins at: 89 Ends at: 104)
LOC:          |      16 |       |      OK |
metrics are OK
LOC_standard_color (Begins at: 106 Ends at: 123)
LOC:          |      18 |       |      OK |
metrics are OK
LOC_RGB_color (Begins at: 125 Ends at: 137)
ParamNBR:     |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
LOC_line_width (Begins at: 139 Ends at: 151)
LOC:          |      13 |       |      OK |
metrics are OK
LOC_erase (Begins at: 153 Ends at: 167)
LOC:          |      15 |       |      OK |
metrics are OK
LOC_move_abs (Begins at: 169 Ends at: 187)
LOC:          |      19 |       |      OK |
metrics are OK
LOC_move_rel (Begins at: 189 Ends at: 204)
LOC:          |      16 |       |      OK |
metrics are OK
LOC_cont_abs (Begins at: 206 Ends at: 226)
LOC:          |      21 |       |      OK |
metrics are OK
LOC_cont_rel (Begins at: 228 Ends at: 244)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_polydots_abs (Begins at: 246 Ends at: 264)
LOC:          |      19 |       |      OK |
metrics are OK
LOC_polydots_rel (Begins at: 266 Ends at: 285)
LOC:          |      20 |       |      OK |
metrics are OK
LOC_polyline_abs (Begins at: 287 Ends at: 307)
LOC:          |      21 |       |      OK |
metrics are OK
LOC_polyline_rel (Begins at: 309 Ends at: 325)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_polygon_abs (Begins at: 327 Ends at: 345)
LOC:          |      19 |       |      OK |
metrics are OK
LOC_polygon_rel (Begins at: 347 Ends at: 364)
LOC:          |      18 |       |      OK |
metrics are OK
LOC_box_abs (Begins at: 366 Ends at: 382)
ParamNBR:     |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
LOC_box_rel (Begins at: 384 Ends at: 397)
LOC:          |      14 |       |      OK |
metrics are OK
LOC_text_size (Begins at: 399 Ends at: 402)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_text_rotation (Begins at: 404 Ends at: 420)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_set_window (Begins at: 422 Ends at: 435)
LOC:          |      14 |       |      OK |
metrics are OK
LOC_text (Begins at: 437 Ends at: 457)
LOC:          |      21 |       |      OK |
metrics are OK
LOC_get_text_box (Begins at: 459 Ends at: 494)
ParamNBR:     |       5 |     * |         |
LOC:          |      36 |       |      OK |
metrics are OK
LOC_font (Begins at: 496 Ends at: 499)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_font_freetype (Begins at: 501 Ends at: 504)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_charset (Begins at: 506 Ends at: 509)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_panel_save (Begins at: 511 Ends at: 517)
CalledNBR:    |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
LOC_panel_restore (Begins at: 519 Ends at: 523)
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
LOC_panel_delete (Begins at: 525 Ends at: 531)
CalledNBR:    |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
LOC_begin_scaled_raster (Begins at: 533 Ends at: 536)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_scaled_raster (Begins at: 538 Ends at: 543)
ParamNBR:     |       6 |     * |         |
LOC:          |       6 |       |      OK |
metrics are OK
LOC_bitmap (Begins at: 545 Ends at: 548)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
  LOC_cont_rel  LOC_reset_colors  LOC_set_window  LOC_RGB_raster  LOC_polyline_abs
In lib/raster/loc_proto.c clones of  LOC_polyline_abs are:
In lib/raster/loc_proto.c clones of  LOC_cont_rel are:
	lib/raster/com_proto.c  R_cont_rel
In lib/raster/loc_proto.c clones of  LOC_RGB_raster are:
	lib/raster/com_proto.c  R_RGB_raster
In lib/raster/loc_proto.c clones of  LOC_set_window are:
	lib/raster/com_proto.c  R_set_window
In lib/raster/loc_proto.c clones of  LOC_reset_colors are:
	lib/raster/com_proto.c  R_reset_colors
Threshold GRASS6 key metrics values at 2007-04-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
