[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/PS/main.c |1
	clones ( main.c )| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Apr  4 06:01:31 EDT 2007
Hello glynn,
ANALYSIS
display/drivers/PS/main.c functions
main (Begins at: 5 Ends at: 10)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  main
In display/drivers/PS/main.c clones of  main are:
	display/drivers/HTMLMAP/main.c  main
Threshold GRASS6 key metrics values at 2007-04-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
