[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/PNG/main.c |1
clones ( main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Apr 4 06:10:30 EDT 2007
Hello glynn,
ANALYSIS
display/drivers/PNG/main.c functions
main (Begins at: 5 Ends at: 10)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
main
In display/drivers/PNG/main.c clones of main are:
display/drivers/XDRIVER/main.c main
Threshold GRASS6 key metrics values at 2007-04-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
