[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/write.c |no
	clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Apr  4 09:20:36 EDT 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/write.c functions
write_dummy (Begins at: 22 Ends at: 25)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
rewrite_dummy (Begins at: 26 Ends at: 29)
LOC:          |       4 |       |      OK |
metrics are OK
delete_dummy (Begins at: 30 Ends at: 33)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_write_line (Begins at: 84 Ends at: 128)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
Vect_rewrite_line (Begins at: 131 Ends at: 185)
ParamNBR:     |       5 |     * |         |
LOC:          |      55 |       |      OK |
metrics are OK
Vect_delete_line (Begins at: 188 Ends at: 216)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
