[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.label/main.c |no
clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Apr 4 22:28:47 EDT 2007
Hello hamish,
ANALYSIS
vector/v.label/main.c functions
main (Begins at: 34 Ends at: 408)
Complexity: | 36 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 137 | *** | MONSTER |
LOC: | 375 | *** | MONSTER |
2 metric are OUT OF RANGE!
print_label (Begins at: 410 Ends at: 432)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 17 | | OK |
LOC: | 23 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
