[GRASS-QA] GRASS QA: hamish |
./grass6/display/d.paint.labels/do_labels.c |no clones | 0
monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 6 03:22:41 EDT 2007
Hello hamish,
ANALYSIS
display/d.paint.labels/do_labels.c functions
initialize_options (Begins at: 44 Ends at: 65)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 22 | | OK |
metrics are OK
do_labels (Begins at: 68 Ends at: 155)
Complexity: | 25 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 47 | * | |
LOC: | 88 | | OK |
metrics are OK
show_it (Begins at: 157 Ends at: 425)
Complexity: | 28 | ** | Warning |
CalledNBR: | 54 | * | |
LOC: | 269 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
scan_ref (Begins at: 429 Ends at: 451)
Complexity: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
xmatch (Begins at: 453 Ends at: 469)
Complexity: | 6 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 17 | | OK |
metrics are OK
ymatch (Begins at: 471 Ends at: 491)
CalledNBR: | 6 | | OK |
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
