[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_arrays.c |4
clones ( N_arrays.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 6 13:29:50 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_arrays.c functions
N_alloc_array_2d (Begins at: 72 Ends at: 131)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 60 | | OK |
metrics are OK
N_free_array_2d (Begins at: 133 Ends at: 168)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 36 | | OK |
metrics are OK
N_get_array_2d_type (Begins at: 170 Ends at: 188)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 19 | | OK |
metrics are OK
N_get_array_2d_value (Begins at: 191 Ends at: 242)
Complexity: | 8 | | OK |
LOC: | 52 | | OK |
metrics are OK
N_is_array_2d_value_null (Begins at: 244 Ends at: 328)
ParamNBR: | 3 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 85 | | OK |
metrics are OK
N_get_array_2d_c_value (Begins at: 330 Ends at: 363)
CalledNBR: | 3 | | OK |
LOC: | 34 | | OK |
metrics are OK
N_get_array_2d_f_value (Begins at: 365 Ends at: 398)
LOC: | 34 | | OK |
metrics are OK
N_get_array_2d_d_value (Begins at: 400 Ends at: 434)
LOC: | 35 | | OK |
metrics are OK
N_put_array_2d_value (Begins at: 437 Ends at: 484)
CalledNBR: | 1 | | OK |
LOC: | 48 | | OK |
metrics are OK
N_put_array_2d_value_null (Begins at: 486 Ends at: 551)
CalledNBR: | 7 | | OK |
LOC: | 66 | | OK |
metrics are OK
N_put_array_2d_c_value (Begins at: 554 Ends at: 569)
LOC: | 16 | | OK |
metrics are OK
N_put_array_2d_f_value (Begins at: 572 Ends at: 587)
LOC: | 16 | | OK |
metrics are OK
N_put_array_2d_d_value (Begins at: 590 Ends at: 604)
LOC: | 15 | | OK |
metrics are OK
N_print_array_2d (Begins at: 606 Ends at: 646)
Complexity: | 4 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 41 | | OK |
metrics are OK
N_copy_array_2d (Begins at: 648 Ends at: 749)
Complexity: | 24 | * | |
ParamNBR: | 2 | | OK |
LOC: | 102 | | OK |
metrics are OK
N_norm_array_2d (Begins at: 751 Ends at: 840)
Complexity: | 18 | * | |
CalledNBR: | 11 | | OK |
LOC: | 90 | | OK |
metrics are OK
N_math_array_2d (Begins at: 842 Ends at: 957)
Complexity: | 23 | * | |
CalledNBR: | 24 | | OK |
LOC: | 116 | | OK |
metrics are OK
N_convert_array_2d_null_to_zero (Begins at: 959 Ends at: 1030)
Complexity: | 10 | | OK |
LOC: | 72 | | OK |
metrics are OK
N_read_rast_to_array_2d (Begins at: 1032 Ends at: 1145)
CalledNBR: | 36 | * | |
LOC: | 114 | | OK |
metrics are OK
N_write_array_2d_to_rast (Begins at: 1147 Ends at: 1285)
Complexity: | 16 | * | |
CalledNBR: | 30 | | OK |
LOC: | 139 | * | |
metrics are OK
N_alloc_array_3d (Begins at: 1287 Ends at: 1341)
ParamNBR: | 5 | * | |
LOC: | 55 | | OK |
metrics are OK
N_free_array_3d (Begins at: 1343 Ends at: 1373)
CalledNBR: | 4 | | OK |
LOC: | 31 | | OK |
metrics are OK
N_get_array_3d_type (Begins at: 1375 Ends at: 1395)
LOC: | 21 | | OK |
metrics are OK
N_get_array_3d_value (Begins at: 1398 Ends at: 1451)
LOC: | 54 | | OK |
metrics are OK
N_is_array_3d_value_null (Begins at: 1454 Ends at: 1537)
LOC: | 84 | | OK |
metrics are OK
N_get_array_3d_f_value (Begins at: 1540 Ends at: 1570)
CalledNBR: | 2 | | OK |
LOC: | 31 | | OK |
metrics are OK
N_get_array_3d_d_value (Begins at: 1573 Ends at: 1604)
LOC: | 32 | | OK |
metrics are OK
N_put_array_3d_value (Begins at: 1607 Ends at: 1661)
LOC: | 55 | | OK |
metrics are OK
N_put_array_3d_value_null (Begins at: 1664 Ends at: 1734)
LOC: | 71 | | OK |
metrics are OK
N_put_array_3d_f_value (Begins at: 1737 Ends at: 1756)
LOC: | 20 | | OK |
metrics are OK
N_put_array_3d_d_value (Begins at: 1759 Ends at: 1777)
LOC: | 19 | | OK |
metrics are OK
N_print_array_3d (Begins at: 1779 Ends at: 1815)
Complexity: | 3 | | OK |
LOC: | 37 | | OK |
metrics are OK
N_copy_array_3d (Begins at: 1817 Ends at: 1892)
Complexity: | 14 | | OK |
LOC: | 76 | | OK |
metrics are OK
N_norm_array_3d (Begins at: 1894 Ends at: 1982)
Complexity: | 15 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 89 | | OK |
metrics are OK
N_math_array_3d (Begins at: 1984 Ends at: 2096)
Complexity: | 22 | * | |
CalledNBR: | 22 | | OK |
LOC: | 113 | | OK |
metrics are OK
N_convert_array_3d_null_to_zero (Begins at: 2098 Ends at: 2161)
Complexity: | 7 | | OK |
LOC: | 64 | | OK |
metrics are OK
N_read_rast3d_to_array_3d (Begins at: 2163 Ends at: 2285)
Complexity: | 21 | * | |
CalledNBR: | 32 | | OK |
LOC: | 123 | * | |
metrics are OK
N_write_array_3d_to_rast3d (Begins at: 2287 Ends at: 2367)
LOC: | 81 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
N_put_array_2d_f_value N_put_array_2d_c_value N_get_array_2d_f_value N_get_array_2d_c_value
In lib/gpde/N_arrays.c clones of N_put_array_2d_c_value are:
lib/gpde/N_arrays.c N_put_array_2d_f_value
In lib/gpde/N_arrays.c clones of N_put_array_2d_f_value are:
lib/gpde/N_arrays.c N_put_array_2d_c_value
In lib/gpde/N_arrays.c clones of N_get_array_2d_c_value are:
lib/gpde/N_arrays.c N_get_array_2d_f_value
In lib/gpde/N_arrays.c clones of N_get_array_2d_f_value are:
lib/gpde/N_arrays.c N_get_array_2d_c_value
Threshold GRASS6 key metrics values at 2007-04-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
