[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.text.new/main.c |no clones | 4 monsters | 1 warnings
Sat Apr 7 06:21:44 EDT 2007
Hello glynn,
ANALYSIS
display/d.text.new/main.c functions
main (Begins at: 78 Ends at: 570)
Complexity:   |      63 |   *** | MONSTER |
CalledNBR:    |     141 |   *** | MONSTER |
LOC:          |     493 |   *** | MONSTER |
3 metric are OUT OF RANGE!
set_color (Begins at: 572 Ends at: 594)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
get_coordinates (Begins at: 597 Ends at: 645)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      17 |       |      OK |
LOC:          |      49 |       |      OK |
1 metric are OUT OF RANGE!
draw_text (Begins at: 647 Ends at: 722)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      12 |       |      OK |
LOC:          |      76 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
