[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_io.c |no clones | 0 monsters | 0 warnings
Sat Apr 7 06:36:35 EDT 2007
Hello glynn,
ANALYSIS
lib/raster/com_io.c functions
get_trans (Begins at: 141 Ends at: 167)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
init_transport (Begins at: 169 Ends at: 175)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
R_open_driver (Begins at: 177 Ends at: 181)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
R__open_quiet (Begins at: 183 Ends at: 187)
LOC:          |       5 |       |      OK |
metrics are OK
R_stabilize (Begins at: 189 Ends at: 192)
LOC:          |       4 |       |      OK |
metrics are OK
R_kill_driver (Begins at: 194 Ends at: 197)
LOC:          |       4 |       |      OK |
metrics are OK
R_close_driver (Begins at: 199 Ends at: 202)
LOC:          |       4 |       |      OK |
metrics are OK
R_release_driver (Begins at: 204 Ends at: 207)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
