[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/draw2.c |2 clones ( draw2.c )| 0 monsters | 1 warnings
Sat Apr 7 14:07:00 EDT 2007
Hello glynn,
ANALYSIS
lib/display/draw2.c functions
alloc_int (Begins at: 78 Ends at: 87)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
alloc_float (Begins at: 89 Ends at: 98)
LOC:          |      10 |       |      OK |
metrics are OK
dealloc_float (Begins at: 100 Ends at: 115)
ParamNBR:     |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
do_convert (Begins at: 117 Ends at: 128)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
dist_plane (Begins at: 130 Ends at: 133)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
interpolate (Begins at: 135 Ends at: 138)
ParamNBR:     |       4 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
clip_plane (Begins at: 140 Ends at: 172)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
do_clip (Begins at: 174 Ends at: 197)
Complexity:   |       9 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
shift_count (Begins at: 199 Ends at: 202)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
shift_angle (Begins at: 204 Ends at: 207)
LOC:          |       4 |       |      OK |
metrics are OK
coerce (Begins at: 209 Ends at: 215)
LOC:          |       7 |       |      OK |
metrics are OK
euclidify (Begins at: 217 Ends at: 247)
Complexity:   |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
do_ll_wrap (Begins at: 249 Ends at: 280)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      32 |       |      OK |
at least 1 values are close to an outlier please consider revising code
D_set_clip (Begins at: 282 Ends at: 304)
LOC:          |      23 |       |      OK |
metrics are OK
D_clip_to_map (Begins at: 306 Ends at: 323)
LOC:          |      18 |       |      OK |
metrics are OK
D_move_clip (Begins at: 325 Ends at: 344)
LOC:          |      20 |       |      OK |
metrics are OK
line_clip (Begins at: 346 Ends at: 371)
CalledNBR:    |      11 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
line_clip_ll (Begins at: 373 Ends at: 395)
LOC:          |      23 |       |      OK |
metrics are OK
D_cont_clip (Begins at: 397 Ends at: 413)
LOC:          |      17 |       |      OK |
metrics are OK
D_polydots_clip (Begins at: 415 Ends at: 446)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
cull_polyline_plane (Begins at: 448 Ends at: 493)
LOC:          |      46 |       |      OK |
metrics are OK
polyline_cull (Begins at: 495 Ends at: 522)
LOC:          |      28 |       |      OK |
metrics are OK
D_polyline_cull (Begins at: 524 Ends at: 536)
LOC:          |      13 |       |      OK |
metrics are OK
polyline_clip (Begins at: 538 Ends at: 544)
LOC:          |       7 |       |      OK |
metrics are OK
D_polyline_clip (Begins at: 546 Ends at: 558)
LOC:          |      13 |       |      OK |
metrics are OK
cull_polygon_plane (Begins at: 560 Ends at: 605)
LOC:          |      46 |       |      OK |
metrics are OK
polygon_cull (Begins at: 607 Ends at: 634)
LOC:          |      28 |       |      OK |
metrics are OK
D_polygon_cull (Begins at: 636 Ends at: 645)
LOC:          |      10 |       |      OK |
metrics are OK
clip_polygon_plane (Begins at: 647 Ends at: 687)
LOC:          |      41 |       |      OK |
metrics are OK
polygon_clip (Begins at: 689 Ends at: 716)
LOC:          |      28 |       |      OK |
metrics are OK
D_polygon_clip (Begins at: 718 Ends at: 727)
LOC:          |      10 |       |      OK |
metrics are OK
box_clip (Begins at: 729 Ends at: 745)
CalledNBR:    |       9 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
box_clip_ll (Begins at: 747 Ends at: 760)
LOC:          |      14 |       |      OK |
metrics are OK
D_box_clip (Begins at: 762 Ends at: 771)
LOC:          |      10 |       |      OK |
metrics are OK
D_move (Begins at: 773 Ends at: 779)
LOC:          |       7 |       |      OK |
metrics are OK
D_cont (Begins at: 781 Ends at: 787)
LOC:          |       7 |       |      OK |
metrics are OK
D_polydots (Begins at: 789 Ends at: 793)
LOC:          |       5 |       |      OK |
metrics are OK
D_polyline (Begins at: 795 Ends at: 799)
LOC:          |       5 |       |      OK |
metrics are OK
D_polygon (Begins at: 801 Ends at: 805)
LOC:          |       5 |       |      OK |
metrics are OK
D_box (Begins at: 807 Ends at: 819)
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  D_cont  D_move
In lib/display/draw2.c clones of  D_move are:
	lib/display/draw2.c  D_cont
In lib/display/draw2.c clones of  D_cont are:
	lib/display/draw2.c  D_move
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
