[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Draw_line.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 7 20:19:16 EDT 2007
Hello glynn,
ANALYSIS
lib/pngdriver/Draw_line.c functions
store_xy (Begins at: 13 Ends at: 19)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
draw_line (Begins at: 21 Ends at: 110)
Complexity: | 9 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 90 | | OK |
metrics are OK
PNG_draw_line (Begins at: 112 Ends at: 135)
Complexity: | 3 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 24 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
