[GRASS-QA] GRASS QA: glynn | ./grass6/lib/psdriver/Driver.c |1 clones ( main.c Driver.c Driver.c )| 0 monsters | 0 warnings
Sat Apr 7 20:19:17 EDT 2007
Hello glynn,
ANALYSIS
lib/psdriver/Driver.c functions
PS_Driver (Begins at: 21 Ends at: 63)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  PS_Driver
In lib/psdriver/Driver.c clones of  PS_Driver are:
	lib/pngdriver/Driver.c  PNG_Driver
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
