[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Graph_set.c |no clones | 0 monsters | 0 warnings
Sat Apr 7 20:19:17 EDT 2007
Hello glynn,
ANALYSIS
lib/pngdriver/Graph_set.c functions
PNG_Graph_set (Begins at: 40 Ends at: 106)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
