[GRASS-QA] GRASS QA: glynn |
	./grass6/display/drivers/XDRIVER/Serve_Xevent.c |no clones |
	0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sun Apr  8 09:35:41 EDT 2007
Hello glynn,
ANALYSIS
display/drivers/XDRIVER/Serve_Xevent.c functions
get_xevent (Begins at: 31 Ends at: 59)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
service_xevent (Begins at: 61 Ends at: 103)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
_time_stamp (Begins at: 105 Ends at: 110)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
check_redraw_process (Begins at: 112 Ends at: 139)
CalledNBR:    |       5 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
list_push (Begins at: 141 Ends at: 147)
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
list_copy (Begins at: 149 Ends at: 155)
Complexity:   |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
list_free (Begins at: 157 Ends at: 165)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
spawn_redraw_process (Begins at: 167 Ends at: 237)
CalledNBR:    |      23 |       |      OK |
LOC:          |      71 |       |      OK |
metrics are OK
handle_resize_event (Begins at: 239 Ends at: 299)
LOC:          |      61 |       |      OK |
metrics are OK
check_flush (Begins at: 301 Ends at: 325)
Complexity:   |       4 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
set_title_busy (Begins at: 327 Ends at: 363)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
set_busy (Begins at: 365 Ends at: 375)
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
