[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.vect/area.c |no
clones | 4 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 8 14:11:49 EDT 2007
Hello glynn,
ANALYSIS
display/d.vect/area.c functions
darea (Begins at: 16 Ends at: 352)
Complexity: | 48 | *** | MONSTER |
ParamNBR: | 13 | *** | MONSTER |
CalledNBR: | 96 | *** | MONSTER |
LOC: | 337 | *** | MONSTER |
4 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
