[GRASS-QA] GRASS QA: scott | ./grass6/vector/v.to.db/parse.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 9 10:54:46 EDT 2007
Hello scott,
ANALYSIS
vector/v.to.db/parse.c functions
parse_command_line (Begins at: 13 Ends at: 160)
Complexity: | 12 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 42 | * | |
LOC: | 148 | * | |
metrics are OK
parse_units (Begins at: 162 Ends at: 174)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 13 | | OK |
metrics are OK
parse_option (Begins at: 176 Ends at: 194)
Complexity: | 13 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 19 | | OK |
metrics are OK
match (Begins at: 197 Ends at: 205)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
