[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/parse_mon.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Apr 10 15:11:21 EDT 2007
Hello glynn,
ANALYSIS
lib/raster/parse_mon.c functions
R_parse_monitorcap (Begins at: 18 Ends at: 104)
Complexity: | 18 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 87 | | OK |
metrics are OK
read_line (Begins at: 108 Ends at: 158)
Complexity: | 9 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 51 | | OK |
metrics are OK
substr (Begins at: 163 Ends at: 186)
Complexity: | 5 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 24 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
