[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.mon/pgms/start.c |no clones | 0 monsters | 0 warnings
Tue Apr 10 15:35:32 EDT 2007
Hello glynn,
ANALYSIS
display/d.mon/pgms/start.c functions
main (Begins at: 50 Ends at: 59)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
start_mon (Begins at: 61 Ends at: 84)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-10 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
