[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.statistics/main.c
|no clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Apr 11 10:38:09 EDT 2007
Hello martinl,
ANALYSIS
raster/r.statistics/main.c functions
main (Begins at: 29 Ends at: 173)
Complexity: | 25 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 64 | ** | Warning |
LOC: | 145 | * | |
at least 1 values are close to an outlier please consider revising code
is_ok (Begins at: 176 Ends at: 182)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
