[GRASS-QA] GRASS QA: martinl | ./grass6/imagery/i.pca/main.c |no clones | 0 monsters | 1 warnings
Wed Apr 11 11:10:25 EDT 2007
Hello martinl,
ANALYSIS
imagery/i.pca/main.c functions
main (Begins at: 43 Ends at: 174)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      49 |     * |         |
LOC:          |     132 |     * |         |
metrics are OK
round_c (Begins at: 177 Ends at: 189)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
set_output_scale (Begins at: 193 Ends at: 222)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
calc_mu (Begins at: 226 Ends at: 275)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
calc_covariance (Begins at: 279 Ends at: 344)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |      66 |       |      OK |
metrics are OK
write_pca (Begins at: 348 Ends at: 516)
Complexity:   |      22 |     * |         |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      51 |     * |         |
LOC:          |     169 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
