[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.colors/main.c |1
clones ( main.c )| 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 12 17:34:29 EDT 2007
Hello glynn,
ANALYSIS
raster/r.colors/main.c functions
rules_files (Begins at: 32 Ends at: 69)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 38 | | OK |
metrics are OK
list_rules_files (Begins at: 71 Ends at: 89)
Complexity: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 19 | | OK |
metrics are OK
main (Begins at: 91 Ends at: 357)
Complexity: | 51 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 119 | *** | MONSTER |
LOC: | 267 | ** | Warning |
2 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
cmp_names
In raster/r.colors/main.c clones of cmp_names are:
lib/gis/datum.c compare_table_names
Threshold GRASS6 key metrics values at 2007-04-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
