[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.watershed/seg/close_maps.c |no clones | 0 monsters | 0 warnings
Fri Apr 13 14:38:04 EDT 2007
Hello glynn,
ANALYSIS
raster/r.watershed/seg/close_maps.c functions
close_maps (Begins at: 5 Ends at: 76)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
