[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/cell_stats.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:02 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/cell_stats.c functions
G_init_cell_stats (Begins at: 34 Ends at: 65)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 32 | | OK |
metrics are OK
G_update_cell_stats (Begins at: 67 Ends at: 173)
Complexity: | 15 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 107 | | OK |
metrics are OK
init_node (Begins at: 175 Ends at: 213)
Complexity: | 2 | | OK |
LOC: | 39 | | OK |
metrics are OK
G_find_cell_stat (Begins at: 215 Ends at: 282)
Complexity: | 7 | | OK |
LOC: | 68 | | OK |
metrics are OK
G_rewind_cell_stats (Begins at: 284 Ends at: 297)
Complexity: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 14 | | OK |
metrics are OK
next_node (Begins at: 299 Ends at: 356)
Complexity: | 4 | | OK |
LOC: | 58 | | OK |
metrics are OK
G_next_cell_stat (Begins at: 358 Ends at: 420)
Complexity: | 6 | | OK |
LOC: | 63 | | OK |
metrics are OK
G_get_stats_for_null_value (Begins at: 422 Ends at: 437)
ParamNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
G_free_cell_stats (Begins at: 439 Ends at: 448)
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
