[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/distance.c |no clones
| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:03 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/distance.c functions
G_begin_distance_calculations (Begins at: 43 Ends at: 81)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 39 | | OK |
metrics are OK
G_distance (Begins at: 83 Ends at: 106)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 24 | | OK |
metrics are OK
G_distance_between_line_segments (Begins at: 109 Ends at: 144)
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 6 | | OK |
LOC: | 36 | | OK |
at least 1 values are close to an outlier please consider revising code
G_distance_point_to_line_segment (Begins at: 147 Ends at: 195)
Complexity: | 8 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 10 | | OK |
LOC: | 49 | | OK |
metrics are OK
min4 (Begins at: 197 Ends at: 200)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 4 | | OK |
metrics are OK
min2 (Begins at: 202 Ends at: 205)
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
