[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/error.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:03 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/error.c functions
G_message (Begins at: 103 Ends at: 131)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 29 | | OK |
metrics are OK
G_fatal_error (Begins at: 133 Ends at: 158)
Complexity: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 26 | | OK |
metrics are OK
G_warning (Begins at: 160 Ends at: 181)
LOC: | 22 | | OK |
metrics are OK
G_suppress_warnings (Begins at: 183 Ends at: 199)
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_sleep_on_error (Begins at: 201 Ends at: 219)
LOC: | 19 | | OK |
metrics are OK
G_set_error_routine (Begins at: 221 Ends at: 235)
ParamNBR: | 3 | | OK |
LOC: | 15 | | OK |
metrics are OK
G_unset_error_routine (Begins at: 237 Ends at: 242)
LOC: | 6 | | OK |
metrics are OK
print_error (Begins at: 245 Ends at: 300)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 56 | | OK |
metrics are OK
log_error (Begins at: 302 Ends at: 337)
Complexity: | 6 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 36 | | OK |
metrics are OK
write_error (Begins at: 340 Ends at: 372)
Complexity: | 4 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 14 | | OK |
LOC: | 33 | | OK |
metrics are OK
mail_msg (Begins at: 375 Ends at: 393)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 19 | | OK |
metrics are OK
print_word (Begins at: 396 Ends at: 447)
Complexity: | 8 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 52 | | OK |
metrics are OK
print_sentence (Begins at: 450 Ends at: 499)
CalledNBR: | 12 | | OK |
LOC: | 50 | | OK |
metrics are OK
G_info_format (Begins at: 501 Ends at: 518)
CalledNBR: | 3 | | OK |
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
