[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/datum.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:03 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/datum.c functions
G_get_datum_by_name (Begins at: 46 Ends at: 57)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
G_datum_name (Begins at: 60 Ends at: 68)
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
G_datum_description (Begins at: 71 Ends at: 79)
LOC: | 9 | | OK |
metrics are OK
G_datum_ellipsoid (Begins at: 82 Ends at: 111)
LOC: | 30 | | OK |
metrics are OK
G_get_datumparams_from_projinfo (Begins at: 113 Ends at: 152)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 40 | | OK |
metrics are OK
read_datum_table (Begins at: 155 Ends at: 208)
CalledNBR: | 15 | | OK |
LOC: | 54 | | OK |
metrics are OK
compare_table_names (Begins at: 211 Ends at: 217)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
