[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.colors/rules.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 23:50:07 EDT 2007
Hello glynn,
ANALYSIS
raster/r.colors/rules.c functions
read_color_rules (Begins at: 33 Ends at: 64)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 17 | | OK |
LOC: | 32 | | OK |
metrics are OK
read_rule (Begins at: 66 Ends at: 123)
Complexity: | 9 | | OK |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 24 | | OK |
LOC: | 58 | | OK |
1 metric are OUT OF RANGE!
badrule (Begins at: 125 Ends at: 133)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 9 | | OK |
metrics are OK
show_colors (Begins at: 135 Ends at: 156)
ParamNBR: | 1 | | OK |
LOC: | 22 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
