[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/find_file.c |no clones | 0 monsters | 0 warnings
Sat Apr 14 19:38:23 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/find_file.c functions
G__find_file (Begins at: 5 Ends at: 106)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |     102 |       |      OK |
metrics are OK
G_find_file (Begins at: 108 Ends at: 156)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
G_find_file2 (Begins at: 158 Ends at: 164)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
