[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/list.c |no clones | 0 monsters | 2 warnings
Sat Apr 14 19:38:25 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/list.c functions
G_set_list_hit_return (Begins at: 61 Ends at: 65)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
G_list_element (Begins at: 67 Ends at: 146)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      18 |       |      OK |
LOC:          |      80 |       |      OK |
at least 1 values are close to an outlier please consider revising code
sigpipe_catch (Begins at: 148 Ends at: 152)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
list_element (Begins at: 154 Ends at: 278)
Complexity:   |      21 |     * |         |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      31 |       |      OK |
LOC:          |     125 |     * |         |
pstrcmp (Begins at: 280 Ends at: 295)
LOC:          |      16 |       |      OK |
metrics are OK
G_list (Begins at: 297 Ends at: 364)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
G_free_list (Begins at: 366 Ends at: 378)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
