[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/key_value1.c |1 clones ( cats.c color_read.c find_cell.c find_vect.c fpreclass.c get_row.c key_value1.c )| 0 monsters | 0 warnings
Sat Apr 14 19:38:25 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/key_value1.c functions
G_create_key_value (Begins at: 6 Ends at: 20)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G_set_key_value (Begins at: 28 Ends at: 100)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      73 |       |      OK |
metrics are OK
G_find_key_value (Begins at: 102 Ends at: 110)
LOC:          |       9 |       |      OK |
metrics are OK
G_free_key_value (Begins at: 112 Ends at: 128)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  G_create_key_value
In lib/gis/key_value1.c clones of  G_create_key_value are:
	lib/vector/diglib/struct_alloc.c  dig_alloc_isle
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
