[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/make_mapset.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 14 19:38:26 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/make_mapset.c functions
G__make_mapset (Begins at: 41 Ends at: 102)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 62 | | OK |
metrics are OK
G_make_mapset (Begins at: 104 Ends at: 121)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
