[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/proj3.c |no clones | 0 monsters | 0 warnings
Sat Apr 14 19:38:27 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/proj3.c functions
G_database_unit_name (Begins at: 21 Ends at: 50)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_database_projection_name (Begins at: 52 Ends at: 80)
LOC:          |      29 |       |      OK |
metrics are OK
G_database_units_to_meters_factor (Begins at: 82 Ends at: 136)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
G_database_datum_name (Begins at: 138 Ends at: 165)
LOC:          |      28 |       |      OK |
metrics are OK
G_database_ellipse_name (Begins at: 167 Ends at: 180)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
lookup (Begins at: 182 Ends at: 193)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
equal (Begins at: 195 Ends at: 205)
Complexity:   |       5 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
lower (Begins at: 207 Ends at: 212)
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
