[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/quant_rw.c |1 clones
	( cats.c color_read.c find_cell.c find_vect.c fpreclass.c
	get_row.c key_value1.c null_val.c opencell.c put_row.c
	quant.c quant_rw.c )| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sat Apr 14 19:38:28 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/quant_rw.c functions
G_truncate_fp_map (Begins at: 64 Ends at: 78)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G_round_fp_map (Begins at: 80 Ends at: 109)
LOC:          |      30 |       |      OK |
metrics are OK
G_quantize_fp_map (Begins at: 111 Ends at: 157)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
G_quantize_fp_map_range (Begins at: 159 Ends at: 196)
ParamNBR:     |       6 |     * |         |
LOC:          |      38 |       |      OK |
metrics are OK
G_write_quant (Begins at: 198 Ends at: 246)
ParamNBR:     |       3 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
G_read_quant (Begins at: 248 Ends at: 254)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  G_read_quant
In lib/gis/quant_rw.c clones of  G_read_quant are:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
