[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/quant.c |6 clones ( cats.c color_read.c find_cell.c find_vect.c fpreclass.c get_row.c key_value1.c null_val.c opencell.c put_row.c quant.c )| 0 monsters | 0 warnings
Sat Apr 14 19:38:28 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/quant.c functions
G_quant_clear (Begins at: 305 Ends at: 310)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
G_quant_free (Begins at: 314 Ends at: 327)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
G__quant_organize_fp_lookup (Begins at: 331 Ends at: 422)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      92 |       |      OK |
metrics are OK
G_quant_init (Begins at: 424 Ends at: 433)
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
G_quant_is_truncate (Begins at: 437 Ends at: 440)
LOC:          |       4 |       |      OK |
metrics are OK
G_quant_is_round (Begins at: 444 Ends at: 471)
LOC:          |      28 |       |      OK |
metrics are OK
G_quant_truncate (Begins at: 473 Ends at: 477)
LOC:          |       5 |       |      OK |
metrics are OK
G_quant_round (Begins at: 481 Ends at: 485)
LOC:          |       5 |       |      OK |
metrics are OK
quant_set_limits (Begins at: 489 Ends at: 498)
ParamNBR:     |       5 |     * |         |
LOC:          |      10 |       |      OK |
metrics are OK
quant_update_limits (Begins at: 502 Ends at: 538)
Complexity:   |       2 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
G_quant_get_limits (Begins at: 540 Ends at: 559)
LOC:          |      20 |       |      OK |
metrics are OK
G_quant_nof_rules (Begins at: 563 Ends at: 567)
LOC:          |       5 |       |      OK |
metrics are OK
G_quant_get_ith_rule (Begins at: 571 Ends at: 582)
ParamNBR:     |       6 |     * |         |
LOC:          |      12 |       |      OK |
metrics are OK
quant_table_increase (Begins at: 586 Ends at: 601)
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
G_quant_set_neg_infinite_rule (Begins at: 605 Ends at: 623)
ParamNBR:     |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
G_quant_get_neg_infinite_rule (Begins at: 627 Ends at: 640)
LOC:          |      14 |       |      OK |
metrics are OK
G_quant_set_pos_infinite_rule (Begins at: 644 Ends at: 662)
LOC:          |      19 |       |      OK |
metrics are OK
G_quant_get_pos_infinite_rule (Begins at: 666 Ends at: 679)
LOC:          |      14 |       |      OK |
metrics are OK
G_quant_add_rule (Begins at: 683 Ends at: 716)
LOC:          |      34 |       |      OK |
metrics are OK
G_quant_reverse_rule_order (Begins at: 720 Ends at: 741)
LOC:          |      22 |       |      OK |
metrics are OK
quant_interpolate (Begins at: 745 Ends at: 756)
LOC:          |      12 |       |      OK |
metrics are OK
less_or_equal (Begins at: 759 Ends at: 763)
LOC:          |       5 |       |      OK |
metrics are OK
less (Begins at: 765 Ends at: 790)
LOC:          |      26 |       |      OK |
metrics are OK
G_quant_get_cell_value (Begins at: 792 Ends at: 899)
Complexity:   |      23 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |     108 |       |      OK |
metrics are OK
G_quant_perform_d (Begins at: 903 Ends at: 917)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G_quant_perform_f (Begins at: 921 Ends at: 935)
LOC:          |      15 |       |      OK |
metrics are OK
double_comp (Begins at: 939 Ends at: 947)
Complexity:   |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G__quant_get_rule_for_d_raster_val (Begins at: 951 Ends at: 961)
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
  G_quant_set_pos_infinite_rule  G_quant_set_neg_infinite_rule  G_quant_perform_f  G_quant_perform_d  G_quant_get_pos_infinite_rule  G_quant_get_neg_infinite_rule
In lib/gis/quant.c clones of  G_quant_set_neg_infinite_rule are:
	lib/gis/quant.c  G_quant_set_pos_infinite_rule
In lib/gis/quant.c clones of  G_quant_set_pos_infinite_rule are:
	lib/gis/quant.c  G_quant_set_neg_infinite_rule
In lib/gis/quant.c clones of  G_quant_get_pos_infinite_rule are:
	lib/gis/quant.c  G_quant_get_neg_infinite_rule
In lib/gis/quant.c clones of  G_quant_perform_d are:
	lib/gis/quant.c  G_quant_perform_f
In lib/gis/quant.c clones of  G_quant_perform_f are:
	lib/gis/quant.c  G_quant_perform_d
In lib/gis/quant.c clones of  G_quant_get_neg_infinite_rule are:
	lib/gis/quant.c  G_quant_get_pos_infinite_rule
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
