[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/histogram.c |no clones | 0 monsters | 0 warnings
Sat Apr 14 19:38:24 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/histogram.c functions
G_init_histogram (Begins at: 22 Ends at: 45)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_read_histogram (Begins at: 47 Ends at: 109)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
G_write_histogram (Begins at: 111 Ends at: 142)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
G_write_histogram_cs (Begins at: 144 Ends at: 173)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_make_histogram_cs (Begins at: 175 Ends at: 200)
Complexity:   |       2 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
G_get_histogram_num (Begins at: 202 Ends at: 213)
LOC:          |      12 |       |      OK |
metrics are OK
G_get_histogram_cat (Begins at: 215 Ends at: 230)
LOC:          |      16 |       |      OK |
metrics are OK
G_get_histogram_count (Begins at: 232 Ends at: 246)
LOC:          |      15 |       |      OK |
metrics are OK
G_free_histogram (Begins at: 248 Ends at: 265)
CalledNBR:    |       1 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
G_sort_histogram (Begins at: 267 Ends at: 304)
Complexity:   |       5 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
cmp (Begins at: 307 Ends at: 327)
LOC:          |      21 |       |      OK |
metrics are OK
G_sort_histogram_by_count (Begins at: 329 Ends at: 343)
LOC:          |      15 |       |      OK |
metrics are OK
cmp_count (Begins at: 346 Ends at: 363)
LOC:          |      18 |       |      OK |
metrics are OK
fopen_histogram_new (Begins at: 365 Ends at: 385)
LOC:          |      21 |       |      OK |
metrics are OK
G_remove_histogram (Begins at: 387 Ends at: 407)
CalledNBR:    |       2 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
G_add_histogram (Begins at: 409 Ends at: 438)
LOC:          |      30 |       |      OK |
metrics are OK
G_set_histogram (Begins at: 440 Ends at: 467)
LOC:          |      28 |       |      OK |
metrics are OK
G_extend_histogram (Begins at: 469 Ends at: 488)
LOC:          |      20 |       |      OK |
metrics are OK
G_zero_histogram (Begins at: 490 Ends at: 498)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
