[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/wind_scan.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 14 19:38:30 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/wind_scan.c functions
G_scan_northing (Begins at: 36 Ends at: 65)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_scan_easting (Begins at: 67 Ends at: 100)
Complexity: | 6 | | OK |
LOC: | 34 | | OK |
metrics are OK
G_scan_resolution (Begins at: 102 Ends at: 111)
Complexity: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
scan_double (Begins at: 114 Ends at: 139)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 26 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
