[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/token.c |no clones | 0 monsters | 0 warnings
Sat Apr 14 19:38:29 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/token.c functions
G_tokenize (Begins at: 32 Ends at: 76)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
G_number_of_tokens (Begins at: 78 Ends at: 101)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_free_tokens (Begins at: 103 Ends at: 110)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
