[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/remove.c |no clones | 0 monsters | 0 warnings
Sat Apr 14 19:38:28 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/remove.c functions
G_remove (Begins at: 45 Ends at: 68)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
recursive_remove (Begins at: 73 Ends at: 99)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
