[GRASS-QA] GRASS QA: glynn |
./grass6/raster/r.out.gridatb/file_io.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 15:46:48 EDT 2007
Hello glynn,
ANALYSIS
raster/r.out.gridatb/file_io.c functions
rdwr_gridatb (Begins at: 7 Ends at: 110)
Complexity: | 23 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 41 | * | |
LOC: | 104 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
