[GRASS-QA] GRASS QA: glynn | ./grass6/imagery/i.class/set_signals.c |no clones | 0 monsters | 0 warnings
Sun Apr 15 17:07:51 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.class/set_signals.c functions
do_quit (Begins at: 6 Ends at: 9)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
sigint (Begins at: 11 Ends at: 15)
LOC:          |       5 |       |      OK |
metrics are OK
set_signals (Begins at: 17 Ends at: 31)
CalledNBR:    |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
