[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.zoom/box.c |no clones | 0 monsters | 0 warnings
Sun Apr 15 17:07:51 EDT 2007
Hello glynn,
ANALYSIS
display/d.zoom/box.c functions
make_window_box (Begins at: 9 Ends at: 133)
Complexity:   |      20 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |     125 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
