[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.proj.seg/readcell.c
	|no clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sun Apr 15 17:07:54 EDT 2007
Hello glynn,
ANALYSIS
raster/r.proj.seg/readcell.c functions
readcell (Begins at: 16 Ends at: 109)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      94 |       |      OK |
metrics are OK
get_block (Begins at: 111 Ends at: 134)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
