[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.edit/vertex.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 17:07:56 EDT 2007
Hello glynn,
ANALYSIS
vector/v.edit/vertex.c functions
do_move_vertex (Begins at: 23 Ends at: 145)
Complexity: | 11 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 123 | * | |
metrics are OK
do_break (Begins at: 147 Ends at: 223)
Complexity: | 5 | | OK |
CalledNBR: | 23 | | OK |
LOC: | 77 | | OK |
metrics are OK
do_remove_vertex (Begins at: 225 Ends at: 292)
Complexity: | 7 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 68 | | OK |
metrics are OK
do_split (Begins at: 294 Ends at: 372)
Complexity: | 6 | | OK |
LOC: | 79 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
